Doris
the green dash light goes out, I take it thats normal?? i.e. it only shows when side lights are on?.
Doris said:the green dash light goes out, I take it thats normal?? i.e. it only shows when side lights are on?.
slowlane said:Mine does that too on dip but there's a blue light that comes on for main beam - switched by the stalk.
Bookwus said:Hiya Tub,
The guy who "fixed" (good use of quotation marks, by the way) your dash wiring screwed up. The green light should only be on when the parking lamps are lit and the headlights are not. Once the headlights come on the green dash light goes out.
Araon said:deffinately not a "learn to live with it" moment....
its a sign of a charging/battery issue, your brake lights draw a bit more current as your no doubt aware, whats it like without the radio or any other extraneous electrics running at night, is there the slightest glow at any other time or merely on application of the brakes, what reg and genny you running and finally how olds the battery/rating?
tubdub said:Araon said:deffinately not a "learn to live with it" moment....
same with or without the radio on. radio is a am/fm cd player with no extra amp. there is just a slight glow [very dim] with the headlights on only when i step on the brakes.the taillight buckets are new repro units. the generator and voltage regulator are about 6 months old. i use a yellow top optima deep cycle battery that is about 3 years old. the battery is from my motorhome bus as the 71 didnt have a battery when i bought it last year so i was going to just use it temporarily but that has turned into a year it was used to run lights and a dvd player in the camper. i will buy a new regular battery for the bus and see if that might have been the problem. deep cycle needs to go back into the motorhome anyway. this bus had been sitting for approx. 10 years when i bought it last year
yep thats me too.......also thought it was a fault glad to hear its normalDoris said:the green dash light goes out, I take it thats normal?? i.e. it only shows when side lights are on?.
