K@rlos said:A 6 rib gearbox is gonna be a bit mighty for a stock 1600 imo
Trikky2 said:K@rlos said:A 6 rib gearbox is gonna be a bit mighty for a stock 1600 imo
Agreed.
I have also never seen a six rib box with the earlier type release bearing, odd. Maybe somebody swapped over an earlier type bell housing?
K@rlos said:Trikky2 said:K@rlos said:A 6 rib gearbox is gonna be a bit mighty for a stock 1600 imo
Agreed.
I noticed this too? Can't understand why as the later style is superior.
Davydomes said:Does anybody know if the 6 rib bell housing is unique to the 6 rib box or does it appear on any other g/box models?
Trikky2 said:Davydomes said:Does anybody know if the 6 rib bell housing is unique to the 6 rib box or does it appear on any other g/box models?
The bell housings can be swapped over but be aware that 6rib housings are for attaching to type4 engines and hence you can't use then on a type1 engine because the flywheel and starter are different. Hence to fit a six rib box to a type1 engine you have to use a bell housing from a 1600 - both early (like you have) and late (with the guide sleeve) will fit.
