jamesurwin
Active member
Unfortunately my 1600tp has given up and will need a complete strip down and rebuild. It's not been bad since I have had the bus but always felt a little sluggish.
Question is, should I get a full rebuild on this engine in the hope that it will be 'back to normal' and reasonably powered, or upgrade to a bigger engine, but ideally without having to change loads of other bits at the same time? I will be keeping the same box etc.
As with most people, I don't have stacks of cash so options are probably limited, but any advice would be good.
My bus is a 1972 crossover if that makes any difference.
