froggy
Was playing around with the wiring today trying to sort out why the indicators and the headlights didin't work.
found 2 relays on the bottom of the fuse board where badly corroded and burnt up. Im guessing these are the H/lights and indicator relays?
The indicator relay is a 5 pin metal relay but there are 3 pins that are all the same (sort of anyway, think it 56, 56a, 56b) and then the h/light is a 4 pin relay.
Is there a modern day equilivilant relay or does anyone know of any electrickery that can be done to allow modern relays to be used?
