FBH fuel tank location…
Ben72Bay
Jul 5, 2021
640
440
Evening all,
Has anyone put a fuel tank opposite the heater? - with each one under the from seats.
Obviously not ideal for filling up but makes use of a dead space and doesn’t compromise any other interior space.
I can’t fit a tank behind the front passenger seat unless I have one made. (I’m not ruling that out, just not sure where to start finding someone to weld one up)
Thoughts?
Ben
Think I’ve decided to put the fuel tank underneath the bus.
I’m sure I remember seeing a ‘torpedo’ shaped tank mounted under the side of a bus. Think it must have had a side filler neck.
Might it have originally been for the cooker fuel perhaps??
Does this ring any bells with anyone???
Some camper conversions had underslung gas tanks.
Unless you get a specific lift pump, I don't think the pump supplied with the diesel heater would cope with an underslung tank.
Why have you decided to not fit the tank behind the seat?
A chap I know called Tom Booth makes custom diesel tanks for buses.
02454220-77AA-4E5B-B265-BC7F70AEFC0A.jpeg05AE77EF-7E0D-4E93-B0EB-4555D1455128.jpegC4BE58A1-13A4-4EC5-9BDF-6A889961DC2C.jpeg
View attachment 6747View attachment 6748View attachment 6749
I love those tanks but I just don’t have enough space behind the front seats sadly.
I’m going to have another look, but I don’t think there is enough space behind there to get anything meaningful.
Only concern I’d have I about venting the tank. No vent means you create a vacuum as you use fuel. And if you have a vent then do you want tank inside the van? External vent is essential
I’ve got a 10ltr tank behind my passenger seat with no modifications at all. 3screws and it’s in! Filler neck sticks out perfectly to fill up.
Thanks @sparkywig !
So I’m not going mad!!
Do you know if there is a modern or repro version of those tanks available from anywhere?
If there is one out there then it seems simpler to buy one then have one made.
These LPG - liquid petroleum gas (i.e. butane or propane) tanks, should not be confused by Americans with gasoline / petrol tanks, who for reasons best known to themselves, misguidedly call them gas tanks.
Wouldn’t do at all would it , blowing up our colonial cousins over the pond.
Ozziedog,,,,,,,,,,We’ll spotted that Nigel :)
