Best upgrades
Neil_in_Belgium
New member
Dec 26, 2024
1
1
Brussels, Belgium
After 1972
T2
I am buying a 1979 T2b. Right now it is in multiple pieces and so the right time to ask "what are the best upgrades"? All suggestions considered but mainly thinking on running gear and electrics for the moment.
Many thanks
Neil
Many thanks
Neil
On the electric stuff, a hot start relay is a no brainer. The name isn’t truly indicative of how good it is. Primarily it relieves a load of strain from the ignition and starting circuits and switches. <<< Mostly correct. Resisting the urge to lower the suspension is a toughy for most. Correct C rated tyres is a fab bonus. And head and taillights are lacking a bit in the modern world but Halos don’t necessarily look that great. While it’s mostly apart, might be an idea to replace the loom with all those old connections. What are you looking for ? A stock look, or a custom thing, or a show winner trailered van ? Patina and originality are sure winners. Anyway, welcome to the forum, what motor you running in there .?
Ozziedog,,,,,,,,,,,,gets some pictures up Neil
What he said!
Plus I’d fit a new loom throughout.
Gives peace of mind, you can configure it to include whatever you might want (such as a hot start relay, auto fire extinguisher in the engine bay etc) and it gives the existing things like headlights the best chance of working to their potential.
Lots!
Soundproofing (everywhere + fire proof foam soundproofing in the engine bay)
Replacing plastic body filler with steel seems a popular upgrade (fingers crossed you don’t have hidden rot)
Wiring as above plus fire extinguisher.
A fuel filter that sits outside of the engine compartment and modern ethanol resistant hoses
Convex door mirrors
Sticky backed card table foam on Westy louver windows to stop rattles
Best thing is to make sure it drives and stops like it should do. Gears should move easily, braking should not pull to one side or another, engine should be slow but equally “powerful” through the rev range, steering should have no dead spots or slack.
Priory?
1 Fuel lines and filter
2 get it running like it should
Big spend upgrades I wish I’d done earlier?
Bigger better engine
Gearbox final drive change to suit engine
Litesteer
Things i needn’t have bothered with….
Radio and subwoofer.
Many thanks
Neil
Hiya, upgrades, hmm🤔
1) Anti roll bar kit = thicker front arb, rear arb and KYB dampers. Difference in handling and motorway driving, vast improvement.
2) Installing thermostat, flaps, flaps, oil cooler bracket, hoover bracket, basically all correct tin ware and associated cooling bits and the later vacuum operated oil bath filter if your engine is stock.
3) Diesel heater, game changer for me whan camping .
4) Led light bulbs, especially headlights preferably from ClassicCarLEDs, plus extra, higher led brake light.
5) Empi gear shifter, other brands available.
6) Don't lower it !.
7) What everyone else has suggested 👍
Some of my best and most useful upgrades to my family's 1973 VW "1600" Type 2 Westfalia Continental, were the earliest ones:
1976 - Fabricated & fitted a home-made stretchy butyl-rubber roof-rack cover, with eyelets & hooks on three sides, and turn-button fasteners adjacent to the elevating-roof.
1976 - 60/55W H4 quartz-halogen headlamp bulbs from 45/40W glass-envelope bulbs
1977/78 - 185 SR14 Reinfored radial-ply tyres from 7.00 14 cross-ply tyres
1977/78 - Retro-fitted front-panel mounted spare-wheel carrier
1989 - 100/80W H4 quartz-halogen headlamp bulbs with uprated circuitry from 60/55W H4 quartz-halogen headlamp bulbs
1989/89 - Retro-fitted, dual remote-acting, vacuum brake servo units in a home-made tubular-steel cradle
1989 - Retro-fitted a home-made, sliding-door pull-close strap
1986 - Substituted Swedish-made SVD wash-wiper blades, with perforated hollow blade rubbers & small-bore, flexible-rubber water-supply hoses
1989 - Retro-fitted 52 mm diameter, VDO Cockpit gauges for oil-pressure, oil-temperature & cylinder-head-temperature
1990 - Retro-fitted a self-modified cross-over-arm, pantograph rear-window wiper system, salvaged from an early-1980s vintage Vauxhall Astra Mk.1 estate-car
Mid-1990s - Retro-fitted Volvo 340 rear-hatch gas struts to the Westfalia elevating roof
Nice one Nigel!
Ozziedog,,,,,,,,,,,and a happy new year bud ! :)
Go through every front end ball joint and replace any with any slop in them. Make sure the steering box is good. Then you should end up with a bus that may blow around still but doesnt have a tendency to leap motorway lanes as the steering slops.
Gearchange- get rid of the stock/EMPI gearshift coupler, use CSP with a turned pin instead of a mild steel roll pin. Use a new front bushing. Check the "donut" in the gearbox nosecone for wear, to improve gearshift.
Commercial rated tyres- if not on stock rims, things like Goodyear Vector 4seasons Cargo style come with stiff sidewalls- intended for bloated EVs and also make a noticeable difference to avoiding being blown around compared with e.g Yokohama car tyres.
LED lights from classiccarleds- at the back much more visible, at the front you can see where you are going..
Glad you came to the party Mike, I’d thought you’d have been on this like an Earlybay on a brakecheck.
Ozziedog,,,,,,,,,,see ya in April bud :)
Another vote
Home made sliding door pull strap.
Slightly different version made from a section of seat belt strap bolted in to the existing bolts. Done one at a time so as to save the adjustment. If it touches the body work it just collapses.
Ozziedog,,,,,,, really let’s you close that slider quietly, useful after midnight :)
My must haves are -
A decent full stainless Exhaust system, will save you **** loads in the long run
Front disks
better beam - Narrowed and adjustable weedeater
a decent carb - Weber 34icts is a good cheeky upgrade for better fuel and a bit more grunt.
Adjustable rear spring plates
Wiring check - All wires front to back check and replace as much as possible, you will find a million not needed wires that can be removed due to changes over the years that can play havoc with earthing issues,
Buttys accelerator roller for the fan housing - keeps that cable smooth
Buttys accelerator pedal linkage upgrade - better by miles than the original!
Plus one for all the Buttys bits upgrades. This thread has turned into a bit of a belter and is reminding me that my wiring could do with a tad more than a bit of insulation tape and redoing the earths,,, again. Be nice to see what’s happening on the dashboard,
Ozziedog,,,,,,,,,and possibly maybe see the road too.:eek: :unsure: :eek:
Loads of great advice and things on here - thankyou all so much for stumping up. As somebody just starting a journey with my 1972 bus this is starting to read like a ‘to do’ list!
Get it on the road and fidget with it at your leisure. You’ll run down less dead ends that way. Get to shows and see what works for others then ponder on what suits you .
Ozziedog,,,,,,,,,, mostly just practice your smiling :)
I just left Buses by the Bridge at Lake Havasu City, AZ. 600+ buses of all vintages. Wish we could have meet up! I picked up a couple of nice things for my 70 bay.
    6.8 MB
    4.5 MB
    4.6 MB
    4.3 MB
    4.4 MB
    4.1 MB
