Hi All,
Firstly Happy New Year.
I thought I would post this to see if anyone else has experienced the same issue. My carb is leaking fuel, only small drips, but leaking nonetheless, from the float champer base - this appears to be worse after the bus has run as obviously the float chamber is holding fuel with nowhere for it to go.
I have had the carb on and off a few times to try and pin point the leak, as the fuel settles on the on underside of the float chamber and just drips from there.
After some investigation it appears that fuel is leaking from around the bolt on the left of the float chamber (looking into the engine bay) and from the acceleration diaphragm on the right. I have replaced the washer on the bolt and this has cured the leak from this side (see picture circled blue): -
However, even after replacing the gasket on the right with a new part, fuel is still dripping from the base of the gasket (see picture, circled red): -
Any hints or tips would be welcome.
Thanks in advance,
James
Thanks in advance,
James
