Supertramp
Is it worth doing? I'll be stripping my engine to replace heads/valves so I was wondering while I'm doing it, is it worth going to 1641? What's involved if so?
Thanks!
Thanks!
Stevec said:I've gone down a different route, more American I think as I posted it on here recently and no one came back saying they've done it. I'm fitting 88mm machine in pistons , not slip in's. The machine in are thick walled so no worries about warping ( I've been told the 88mm don't unless you thrash it). Anyway there is machining required but only on the heads to 92/90.5mm. It all works off the 69mm cam to so no splitting off the case required. It should bring it up to 1679cc.
I'm doing it in Nov so I'll take pictures and put a thread up, fingers crossed she's goes sweet as I have Europe planned next year too.
Steve
andyo11 said:Wouldn't bother with a 1641 at all, still no torque, if you want some real performance go for at least a 1955, lots of torque to get up those hills and extra speed aswelland won't cost you much more than a 1776 !
Marriedblonde said:I started off going for a 1914cc but ended up going for a 2187cc unit instead. Bigger the better I reckon.
I'd suggest seeing if you can have a drive in a bus with the size of engines you are looking it. Obviously get one with a similar set up. I don't think a 1641cc will make much difference, except that your old engine may be tired and there fore going back to the power it left the factory will. If you know what I mean.
I drove a mates 2007cc before I decided and the difference in performance is amazing, being able to keep up with traffic on hills etc makes the bus so much nicer to drive.
dubdubz said:honestly you should tackle this from the other direction
budget and partly time
how much do you have of either - seriously set a budget and unless you are in a position to 'find more' if you just increase to 1955cc for example
simple way [ and I mean this sincerely] is do your own pricing research.
Ring TES or someone who does machining and ask for the cost to machine heads and case - in fact get a menu of machining
Factor in next the cost of the goodies from say VWheritage and then decide if you can do it yourself.
It is possible to do yourself, and that is where the knowledge on here is invaluable but you have to factor in if when you are measuring and measuring again, if something is out of tolerance, it may have to go back to machine shop to sort.
The way I did mine was to strip, measure and send off case. This isn't a next day thing of course - which is where the time question came from.
I would as a final point make sure the engine is standard width - when you get into 'stroker' tinware doesn't fit etc and you need shims for deck height and the like. I built a mini stoker out of curiosity [76mm crank and std size top end= 1745], because a s Trikky says the case needs to be checked, and whilst you're in there a new crank is only the cost of a new crank - you should be doing new bearings etc anyway. The hardest part was setting deck height and altering the tinware for me.
If I had to do it again - I'd go 1776 - though using a 69mm CW balanced crank instead of stock. I had also bought the dells and a decent exhaust, anything above 1955 is really stretching the 36's I'm reliably told [ not sure if that is true but seems reasonable ?]
Then there's the additional power and making sure it stops - that has to be factored - a bus that can be more modern in its velocity overall - probably needs either a rigid maintenance of the drums [drums are pretty good in general] or swapping to disks and decent pads...
Supertramp said:Thank you both, good reads. I'll have to do some more research. I started off thinking while the engine is being stripped is it worth a bolt on upgrade to 1641 but this then leads whether I should upgrade even higher. To be honest I don't have a huge amount of time either, we're leaving in March and the winter period is quite busy for us. Really want the bus running as soon as too. So much to think about with these things, it's never simple. Got 15 other decisions related to the interior to make, let alone colour choices...COLOUR CHOICES!! :lol:
Supertramp said:andyo11 said:Wouldn't bother with a 1641 at all, still no torque, if you want some real performance go for at least a 1955, lots of torque to get up those hills and extra speed aswelland won't cost you much more than a 1776 !
Why stop at 1955? I can see where this is going...
I was going to be happy with my 1600 and twin carbs but as the heads potentially need replacing anyway, it got me onto thinking about upgrades to power. I really don't want a huge engine, just something reliable that keeps speed.
In terms of cost, 1641 is a bolt on kit (correct?) like Alex posted at around £480-£500
1776 would involve a new cam and machining so we're talking what £?
Don't want to go higher than that as I want to start diverting my funds away from the engine and onto interior goodies.
