1970 Dormobile
Hodge
Jan 29, 2013
52
31
Hi All, thought it was about time I started a build thread for my 1970 RHD Dormobile
Owned my bus now for about 15 years now and had various bits of work done to it over the years to keep it on the road but the time has come to dig a bit deeper!
I had the front chassis legs replaced a few years back so I knew the front end was good but the bus was fitted with welded on belly pans which I've always wondered what was hiding under there.
So last year I decided to cut them off and strip the interior out to see how things were looking 😬
Hodge
Jan 29, 2013
52
31
Floor wasn’t too bad but inner sills completely rotten. Chassis legs need work, both tubs need replacing and a whole lot more!
ozziedog
Jan 24, 2010
6,978
908
East Brizzal
Yup, mine never had pans on but after loads of different work over the years , I’ve had side pans put on and painted up good both sides and mine are bolt on so as I can drop em down every so often. I’ve got a pedal pan that i rescued and cleaned up and painted but that was ten plus years ago and I still haven’t got it on, mainly because I keep promising to reinstate the original horn system. I’ve just bought some mud flaps toooo try and look after things and that’s another nest of what brackets shall I use ;) So great idea having a look and great idea starting a thread and it don’t sound like you’ll take as long as me to do stuff.
Ozziedog,,,,,,,it’ll be fine for sure :):cool::)
YellowBay69
May 27, 2019
310
194
Year of Your Van(s)
1969
Van Type
1969 Bay Window
I feel your pain. I removed mine to get to the chassis only to find lots of rot !!!
All sorted now though. I believe Dormobile welded them in to add strength as the roof aperture is so big.
Good luck 🌈👍
Hodge
Jan 29, 2013
52
31
Yeah at first I was hoping to get it sorted in a couple of months but now I know that’s going to happen! I can’t weld myself so a friend is doing the work but other projects he has dragged on longer than expected so he will just be dropping onto it when he can.
I decided to buy a T5 to use in the meantime as I think it’s going to be a long term project!
As for the belly pans I had heard about them been welded for strength but they’ll not be getting welded back on. Good idea about bolting them on.
Hodge
Jan 29, 2013
52
31
Few more pics of it stripped down.
Need to remember to take more pics!
Hodge
Jan 29, 2013
52
31
Update, one side about done. New sills, outriggers, jacking points, rear tub and arch, Chassis legs…. The list continues!!
Dizzy T2
Active member
Nov 23, 2022
37
6
Ireland
Year of Your Van(s)
After 1972
Van Type
VW T2 Dormobile
Hi Hodge
Silly question what type of metal are you using to fill in the holes on the floor and panels?
Dizzy T2
Active member
Nov 23, 2022
37
6
Ireland
Year of Your Van(s)
After 1972
Van Type
VW T2 Dormobile
Hi Ozziedog
Are mud flaps a good idea, or is it the Tesco approach every little helps
ozziedog
Jan 24, 2010
6,978
908
East Brizzal
Hi Ozziedog
Hiya Dizzy T2, yup I reckon they’re a great idea. Anything that limits the amount of crap collecting inside the arches on the lips has got to be a good thing in the the constant battle against them rusty termites. I’ve not get the brackets yet but I’m on the lookout for some stainless brackets, so I’ll probably need to get some Buttys bits brackets as they’re supposed to be top drawer.
Ozziedog,,,,,,,, And keep it off everything else as well. :)
Whistler
Nov 28, 2012
926
47
Herne Bay, Kent
Year of Your Van(s)
1970
Van Type
Devon
I got some the other week with the throttle kit. That is brilliant. Not fitted the mud flap brackets yet, but I have offered them up and they are indeed top draw. I will have to drill a new hole in the mud flap themselves, but I suspect that is the flap and not Butty's kit that is the issue.
Hodge
Jan 29, 2013
52
31
Spent a bit of time today cleaning the gearbox up. Got the thick off but still needs more work. Should have took a before pic!
Any recommendations on painting it?
ozziedog
Jan 24, 2010
6,978
908
East Brizzal
I don’t think it’s about the paint bud as I think it’s 99.99999 percent to do with the prep. It’s also not gonna get outrageously hot there. I dare you to paint it pale peach with beautiful spots on it.
Ozziedog,,,,,,,,,, I double dare you :)
AircooledKate
Jan 4, 2013
121
17
York
Year of Your Van(s)
1970
Van Type
Adventurewagon
I have the throttle kit, was it as easy to fit as it says? I need to crack on and do that over winter.
Whistler
Nov 28, 2012
926
47
Herne Bay, Kent
Year of Your Van(s)
1970
Van Type
Devon
I think so yeah. I reckon if I had to do it again it would take me an hour or two tops.
The hardest part was the rod through the chassis as mine I presume was rusted solid so wouldn't come apart (can't even tell where it should come apart). I had to cut the end off where it links to the cable. I had to use a multi-tool which worked perfectly. I also had to use a right angle drill to but the holes where it bolts on the top hat section. Other than needing some specific tools (which I had already) it's very simple and makes a massive difference.
AircooledKate
Jan 4, 2013
121
17
York
Year of Your Van(s)
1970
Van Type
Adventurewagon
Ah that’s good to know thanks. I’ll have a look at fitting that over winter then. What were the specific tools you found you needed?
sparkywig
Administrator
Staff member
Administrator
Moderator
Feb 9, 2008
12,490
1,029
mostly here, sometimes there
If yours is lhd you don't have the crossbar through the chassis. Just a 10mm socket and spanner is required, along with a hex key to adjust the pedal stop. A small 8mm spanner comes with the kit to fit the linkage to the pedal.
