68_early_bay
Oh.my.god. :shock:
Talk about acceleration 8)
Thanks Alistair! Yes you've pretty much nailed the concept. I was considering using some rubber landscaping "bender board" to do it, it's a little bit more low profile than the mud flaps and very inexpensive. I don't want anything hanging down too far to be visible from the outside of the bus. But if they don't work because they're not large enough, these flaps would probably be the ticket with a bit of trimming.aogrady said:Amazing conversion, absolutly love it!
A thought on the cooling, you mention a air dam in front of the engine, would something like those truck/bus rear mudflaps do?
Maybe this would create a low pressure area, which may have a benefit of creating low speed cool air for the filter intake?
I think the Porsche grille would look really nice and clean but still contribute to the problem and also give away that something is "not quite right" with the bus. The only thing I want to give that away is some tire smoke and some shrinking tail lights. :lol:aogrady said:Interesting about how the engine lid being open and the bumper affect the heat, probably a similar effect to a air cooled engine running hotter temps with the lid open....as you say, the pressure/aiflow must affect how the hot air pulls the cold air in, probably basic physics, but it's too late in the evening for me to figure it out aerodynamics :lol:
Wonder how running something say, like a Porsche 356 air grill would look where the license plate is? Or would that have a negative effect as noticed above? Sounds like a cardboard engine lid to modify air holes and some data logging equipment needed! :lol:
There is a surprising amount of pressure created by the stock vents and my little JK scoops. I get the feeling that this idea will probably end up killing a fan motor.aogrady said:Could you reverse one fan, (stick it the other side of the rad) so it pulls the heat away from the opposite rad, and up and out of the half moon vent? I assume the fans only run when in slow moving or standstill traffic? When moving at speed, the air in through the vents can still pass through the rad, but pull it out when going slow?
Thank Al! I did ask Jeff to cut a hole in my deck lid and stand off my plate but I think this was counterproductive in my case because of the excess heat from my rads may be getting directed into the hole by my bumper. I am going to remove my plate standoffs to see if that changes things for the better.Bundy said:Hi,
Loving your work on this conversion.
Another thing I did was cut 6 large holes behind the rear number plate and stand it off the engine lid with a couple of rubber grommets...I reckon that's helped keep better airflow out of the engine bay as it never seems overly hot in there after a long run anymore.
Good luck with it...oh, the gearbox will transform the drive! I had mine rebuilt with the 091 c+p and a taller 4th...cruises beautifully and 1st is useful too now :lol:
Al
PS: Fit a rev counter...that way you know it's still running when at the lights! I had to as couldn't hear it
Up until I blew up my T1 engine I had been replacing all the suspension and brake components so it is surprisingly stable at 90-100mph. I only need to replace my drag link and work on my steering box because turning the wheel does not feel smooth at low speeds. But yeah, buses should not be driven like this, it's just not gonna work out very well if something happens.marco said:Scary stuff! Mine's scary at 50, let alone double that 8)
Bundy said:Do you know what gear ratios you used on you gearbox?
I had the 4.57 final drive (as per an 091 gearbox) and a 0.82 4th gear fitted in mine.
Quite a bit jump from 3rd to 4th, but the engine is more than capable.
70mph is just under 3500rpm now
Al
Pretty cool split is that.LEEP said:Yeah Andy, Carlos' bus turned out really nicely, he painted his radiator box green like a coleman cooler or a stove or something so it will blend in with his other roof rack accessories. He has driven it down to LA from the Bay area (6+ hours each way) and he has also taken it to Portland, OR and back (10+ hour drive one way). It certainly has no issues with cooling since it's got frontal area exposure (lol) to air flow. Not as un-natural as my setup. Anyway, a couple of pictures of his bus:
The 914 is for sale, BTW.
LOL Alistair, thanks for keeping the thread alive. As you know I have been busy but pretty much just posting to Instagram.aogrady said:Any more updates? [THUMBS UP SIGN][WINKING FACE]
