So here we are, a long awaited, much anticipated update on my beloved bus…
If you’ve read my previous posts you’ll know I’m very far behind on updates, I still am but thought I’d finally get round to posting another as I’m very bored in a premier inn (away with work)
This is the first update where I have taken over the project from Karl. He still comes over now and again to give me advice and see how I’m doing but it’s (mostly) me from here on out.
the following repairs were the first I tackled all on my own. I admit some mistakes have been made, looking back even now, I’d do things maybe a little differently but I promise the quality of my welding and finishing does improve
first things first, here is what was left of the rear corner after a previous “repair”. I discovered that it was a panel, brazed on top of a panel and filled over. I mean come on?!
So it all had to go
First bits I tackled were the rear arch closing panel and the back side of the rear arch, I’m not 100% sure I won’t need to change the whole rear arch as I have since discovered a few bits that need attention on the bottom part of the roll, however being a 71 with the one year only arches, I’ll cross that bridge later on in the project. I think I’ll be able to come up with something. In terms of the rear arch panel, it does look a bit cooky in the photo but it is better in real life, I just need to trim the return a tad…
First step on the D pillar was clop it in half so I could properly weld it to the back part, then weld the front bit back on. Only technical terms here haha!
Finally time to get the battery tray and rear corner in! This bit was a bit fiddly as you’ll see in the photos. I’ll just describe what’s going on here rather than little bits of text between each photo. So we have the corner without the return, the just Kampers return for the bit against the rear arch, a section I made myself that extends up (and is a strange shape, I still have a lot to learn) And finally a section of early wheel arch I accidentally bought but that perfectly matches the curve of the rear corner. Enjoy
I did finish this repair, but for some reason I didn’t get any decent photos of it complete so I’m afraid this dodgy one will have to do..
I’ll grab a better photo tomorrow when I’m back from work to show the final article up close.
Considering this was the first real chunk I took on myself, I’d give myself a mediocre 6-7/10 for this one. I think I could have simplified a few bits, and also removed the transport primer before I put it all in (I’m dealing with this as an ongoing pain in the arse job) but overall with a little filler it’s a lot better than it was!
I have a few more updates ready to go so I’ll try and do those maybe next week so I can start posting up to date bits and bobs..
