What a waste of a day. Big plan is to get the 34PICT4 running with a standard setup, including the oil bath filter and a new Bosch SVDA dizzy. So having got it pretty ok (and better than with the 009), I decide on further refinements as it's poor in the cold and still drinks fuel. Cleaned out the oil bath filter with paraffin and petrol (see my other thread - that's not so good either).
So an easy day putting all back together and getting it to run sweet - NOT!
It's now worse than when I started. I just can't get it idling nicely - it hunts between 800 and 1000 rpm, changing every 10 seconds or so. The idle air screw is nearly shut off to keep the revs down and the idle mixture is probably 5 turns out. Set the throttle stop screw as per Rob n Dave's pages (3 thou gap then in half a turn). Tried a different idle jet (same size) from another carb and that was worse - sounded like a tractor! The hunting implies an air leak or a rich mixture. I've searched for a leak - including disconnecting the brake servo pipe - but I can't find one.
I've set the timing to 7.5* btdc, but that moves around with the idling. And then at 3000 rpm, its over 30* btdc - more like 40*. If I back it off towards tdc, it just runs rougher.
Loads and loads of twiddling has seen it drivable, but changing up a gear, it's hesitant and lurches - just like it did with the 009. Clearly, I fluked it the first time I set it up and now I can't get it back.
So, I'm thinking it has me beat.
Does anyone know of a tumner who REALLY knows about air-cooled in teh Ipswich area? Please?
Nick
Nick
