- Joined
- Oct 14, 2017
- Messages
- 128
- Reaction score
- 57
- Location
- Birmingham
- Year of Your Van(s)
- 1971
- Van Type
- Panel van / Camper
Going back to tuning carb, did you set throttle stop screw before touching anything else?. Must be done or everything else is a waste of time.I'll wind it back 2 degs. Thanks for the advice.
I've found an air cleaner stand but it's in the US. I'll have to make it bolt-on somehow.
Carb tune this weekend and I think the bus will be more useable.
Also check choke when cold, flap should be open a tad, not tight shut. If adjustment required slacken the three screws and rotate choke body as necessary, just pinch up screws, often overtightened. Ignore raised marks on casting.You probably know all this anyway.
Try davidoft for a filter stand.
Which type oil bath have you?, there are 3 types. The later vacuum operated type by far the best.
