bluenose
my carb is in need of a bit of attention. I'm hoping someone can give me a bit of advice as I'm not sure what to do for the best;
1 by bluenose1982, on Flickr
First pic I'm not sure what this arm is which I've circled in red? it flaps around loosely all over the place and doesn't seem to have a job to do, there is a ball on it which looks like it was for some sort of linkage, can't see what though. Also there is some play in this shaft.
2 by bluenose1982, on Flickr
second pic the fast idle cam wobbles around everywhere, so much in fact the idle screw has completely missed it :lol: also there is about a 1mm side ways play in this shaft.
3 by bluenose1982, on Flickr
third pic, the lever for the accelerator pump turns about 1mm before it even moves the linkage rod. I guess this isn't normal.
I've read the 30 pict 2 is not the best of carbs. Are parts available for me to repair it or will it be a scrap heap challenge?
Is there a suitable replacement carb I can bolt straight on which will have the correct vacuum signal to work with my low cap vacuum only distributor.
Any advice appreciated as always!
