mattp
I have a 1970 LHD early bay running on original wide 5 drum brakes all round. The van stops fine but I would prefer disks and as I want to run Porsche pattern rims it makes sense to go with early 944 (pre '86 single pot calipers) front brakes and late baywindow rear brakes and creative hubs and drums. I have now bought some 130PCD wheels, anearly 944 front set up, late bay running gear, new internals, a 944 conversion mount kit and will hopefully collect the CE hub/drums this month too.
What master cylinder should I run as despite reading as many threads as I have found I still have no idea, nobody is letting on? I have no servo on my van and because of this I would prefer not to fit one (although I have a manifold to do this should I want to go down this route) Iwill be fitting a splitscreen beam later on in the summer and that rules out an original VW servo.
Advice welcomed on which M/C and also whether I need to buy a bias valve to go with this as they are £165ea new...........
A couple of other questions
1) do late bay hubs bolt to early springplates and A arms to do I need to bolt on the whole late bay rear end?
2) I assume I need to fit late baywindow (71-79) handbrake cables too?
Thanks in advance, Matt
