Air box
the cheaper option is the t25 091 box, but you need to be aware its selector is on the side and not the end, so you either source a bay nose cone or engineer a new lever to use the side selector....
(the 25s are a lot cheaper and well worth a thought if your going this route)
well its nice to know there are different options available, i'll keep that thought in mind ;)
i was going down this route then found out how hard and expensive it is to swap the nose cone to fit a bus so i sold the t25 bus box on and found an AT code 1303s box for £20, result! 8) , road house retro do a bolt up conversion that allows you to fit this box with a much taller 4th.
Mark (Axlfoley)
Are you still after a air box stand and the airbox bits, I'm in the process of cutting mine off at the minute and I no longer need the airbox as i'm fitting twins. Just a thought, this thread is a bit old but thought I'd ask before cutting the stand to bits to remove, if you want it i'll do my best to preserve it.
Let me know i'm in the area about 8miles from junction 24 (Coldra, Newport) towards chepstow.
Ben
