rustydiver said:Interested to see how this pans out. Want to sort out the suspension on the pick up, mainly the rear to allow me to raise it up a bit when under load. Putting canoes and bikes in tne rear with camping bits lowers it a wee bit.
Could you do this front and rear.
I know a mate who has put on air shocks on the front of his spli screen so he don't hit the radiator on the underside when going on and off the ferries
Alisdair did you sort anything out?
rustydiver said:Now a real dumb ass question, do I need a onboard compressor on the van or a double barrel foot pump do the job for pumping up the rear.
Want to fit something to the rear of the pick up, so when we load up with bikes, canoes and camping gear I can have a bit of rear suspension, hardness donesnt bother that much cos when it's empty at the rear it's a hard bouncy ride. The van I mean. :msn4: could the same be done for the front too?
stuif said:I'm going to get my airshocks (front) next week :bliss:
I'll have a chat with the guys from T2D this saterday at the hot chocolate party at Kieft and Klok over here in Holland.adamski said:stuif said:I'm going to get my airshocks (front) next week :bliss:
Are you going the T2D route? I'd love to hear the results (either publicly or via a PM). I am probably going to go this route too.
stuif said:Got my shocks and fitted them on my (narrowed) neam
And fitted
Hope you can see the pics :msn4:
Matt Maz said:This ^^^^^ sounds very similar to my set up, although I don't have any air shocks on the back.....I'd be a little worried due to the weight of the van.
As for the front, it is great being able to adjust the pressure from the cab. I've also had the top shock mount moved and a bracket for the bottom mount made up to help with the lift.
As mentioned this won't act as a full air ride kit as the speed isn't fantastic and the lift at maximum will only be around 5cms, however this does help with any small bumps/ramps!!
I've got the Monroe shocks, if you want maximum lift then you really need to go the route of John the Horse which is awesome or the air ride technology shocks from airkewld, that said these are a much more expensive route than the Monroe shocks!!
Just my opinion
