Shit, I have not up dated this for ages. Life just gets too busy to sit at the 'puter.
So, ignition is all running sweet now. If anyone needs help or advice on a mega jolt let me know.
Since then I added a Huco 2.5 psi fuel pump from eurocarb (thanks Matt). I did take the precaution of adding an inertia cutout switch from a Rover (£10 from eBay) and this feeds the pump and the fuel cut out solenoid so all fuel stops if I have a bump.
Then next on the agenda was fitting one of Gadgets tow bars, a substantial but if kit but needed a little fettling to fit my van.
I was running a hidden pipe Vintagespeed Superflow, but this will not work.
So I sold that and ordered a standard pipe Superflow system from Dan the man.
And fitted:
The tow bar is wired with 7 core cable, terminated with piggy back spade connectors to make it easy to instal and remove if needed.
All this because I bought this little gem :
I'll be lobbing on a set of EB rear lights to match mine and then a coat of L90D.
And to finish this post off a few photos of us using Bart this year. Will be away next weekend for the final weekend out before winter upgrade time.
One from when the idler wheel bearing failed...
The recovery chap only had one arm and was a star, absolutely amazing and did a proper recovery job.
Bearings and bolt replaced now, thanks to eBay !
And a few of the other toy:
Caterham is for sale now
Well that us it for now. Winter projects include painting the tin wear, engine bay, wiring in a stereo, new internal panels and rust proofing cavity waxing..
