aircured
what is the best way to totally remove ball joints (to replace them with new). :shock:
van fan said:what is the best way to totally remove ball joints (to replace them with new). :shock:
stagger lee said:getting old joints out are a breeze, it's getting the new ones in. you need access to a press and some appropriate drifts.
1. grind the back of the joint out.
2. knock the taper and ball out.
3. clean out the grease.
4. feed a hacksaw through the joint case hole.
5. saw through the joint case, carefull not to cut into the trailing arm.
6. collapse the joint case and knock it out.
may seem longwinded, but you can do all four in less than an hour easy.
dubdubz said:be careful though...the surcharge will not be paid on arms that they say cannot be refurbed ..and rumour has it they are getting choosy on that..as they are not keeping the stock levels because when I phoned he said that there were a lot of arms that were not passing the scrutiny........just a cautionary word......
D
dubdubz said:I spent ages making a version of the real vw tool 459 1 and 2 btw...about $200 from the US...I digress
which because the joints had rusted in over the years was impossible to remove with a 20ton press, a quick chat found others had seen in excess of 30tons and struggling to shift....
van fan said:dubdubz said:I spent ages making a version of the real vw tool 459 1 and 2 btw...about $200 from the US...I digress
Would appreciate any drawings / pictures of your home made vw tool etc...
