Roxy2, our 1971 model, 1970 year, tin top camper van.
Ø Asking price is based on similar vehicles I have seen for sale but prices can vary greatly so I am being open minded with offers or swap for T5 (can be of less value with cash our way) as we don't want to give up the VW scene.
Overview - Reluctant to sell up as we've had some good times in her but due to changes in circumstances we need to as I don’t have the time to maintain her like I used to. Restored 5 1/2 years ago, there is some small areas of rust coming through the usual places now but is in a very good condition, and is a solid bus. Absolutely loads of work and extras done on this bus with intentions of keeping it. We have even spent over £2700 this year alone upgrading the suspension, steering, brakes and wheels.
1641 engine, twin choke weber carb fitted 2009. Red 9 twin wishbone with coilovers, steering rack, remote brake servo and Porsche Fusch replicas with new tyres – All these were fitted May 2013 and have done less than 1000 miles. Fitted with endless cupboards and a 3/4 r&r bed. 240 v hook up, 12 v leisure circuits and leisure battery. Fridge, cooker, sink. And much, much more, too numerous to list at the mo.
More details in no particular order,
An original minibus so this is not a van conversion. UK from new and converted to the original interior by Danbury, though none of the original Danbury interior exists.
Purchased in 2008 as a grey primed running shell and restored by August 2008. We completely stripped out, had it professionally resprayed, all windows and doors refitted with new seals, fitted ply flooring and carpeted it. Upholstered the seats in vinyl to the front. New mdf panelling to the rear, all covered in wadding and upholstered along with the rear seat and walk through bulkheads in Porsche upholstery fabric. New headlining and a Full set of complimenting curtains.
Original tin top with no cutouts in side panels for electric or fridges. Averages 26-28mpg with a trailer on a good run averaging 55mph.
TAX FREE
MOT Jun 14
New -The Engine Shop, 1641 unleaded engine fitted new 6k miles ago Jan 2009, including new complete clutch, twin choke weber 32/36 carb and manifold, 009 dizzy, air filter, ignition leads, coil etc and main battery at the same time
New - Petronix electronic ignition Jul 2010
New brake master cylinder, brake calipers and rear wheel brake cylinders fitted, along with pads and shoes Aug 2008
New - Empi Quickshift Gear Lever Oct 2008
New - standard exhaust Jun 2008
New - 55Ah alternator conversion Feb 2008
New – Fuel sender Mar 2008
New – 1kg Automatic Foam Fire extinguisher fitted in Engine bay Jul 2013 (£160)
New – Porsche Fusch Replica wheels and tyres Jun 2013 (£400 & under 1000 miles)
New - Red 9 Design Twin Wishbone Coilover suspension and steering rack with new brake discs and wheel bearings Jun 2013 (£1800 & under 1000 miles)
New - Remote brake servo giving fully servo-assisted brakes - discs to front and drums to rear Jun 2013 (£400+ & under 1000 miles)
Split charge system for leisure battery with built in mains battery charger to top up / recharge the leisure battery when mains voltage is available.
12 volt leisure lighting and 'cigarette lighter type' points in the rear (2 at rear seat' 1 by rear hatch, running from either the leisure battery (replaced 2013) or via an in built regulated 12volt transformer when connected to the mains.
Power display and control panel. Displays power draw (current) and voltage. Controls either leisure battery supply or 12volt supply via the mains transformer. Both individually fused.
Jvc cd/radio ICE with 4 kenwood speakers, ipod compatible, runs from leisure battery for normal use and its memory is from the main battery.
Sink and drainer with tap and 12 volt water pump, powered as above.
Overboard waste and fresh water stored on board.
12v / 240v fridge which is powered automatically from the best source available via a relay.
Mains supply socket (blue camping type) connected to a 2 gang fuse board with 2 double onboard 240v mains sockets.
Twin hob and grill cooker with gas, fitted in a removable cupboard with storage for pots and pans and also incorporating a lockable key/ wallet safe.
Lots of cupboard space maximising the use of every available piece of space for storage including an overhead locker in the rear.
3/4 rock and roll bed with under storage.
Removable single leg table which is stored under the overhead locker
Dashboard vents have been modified to incorporate fans to give blown air.
LED upgrade dash warning lights and VDO fuel gauge and new sender unit
3 additional gauges on top of dash, fitted so as not to cause any changes/ cuts to the dash top itself, battery voltage, oil temp and an analogue clock
The locks are all key matched except for the ignition and fuel filler cap.
Aluminium side step
Powder coated in white, front and rear bumpers and steering wheel.
Genuine VW 2 bow roof rack which has been modified to sit lower to the roof.
Tow bar.
Windows legally tinted for privacy in the cabin.
Winter cover and Haynes manual included.
Also I started writing an owners manual, like a Haynes, detailing all the changes and additions which I will include.
Also available and not included at the asking price would be the 4 x 3ft teardrop trailer I built and painted in matching colour. Built in Eastern European external ply (better than marine grade) with a steel frame, new wheels and tyres, fully lockable gas strut opening hatch, steel mudguards and matching early bay lights. Also a spare wheel and wrench.
Also I have some spares and specialist tools, which will be of no use to me afterwards so these are available for purchase too, such as a CO2 analyser and timing light.
Bad points – obviously a bus this age isn’t going to be perfect:
Nothing major. A few minor mot advisories this year, wheel bearing play on both sides, these were new bearings just prior to the MOT so just needed retorquing. Oil leak, nothing to worry about, they put this on all my mot'd vehicles.
There is rust starting to come through on passenger door lower edge, sliding door lower edge, both rear corners and a few other minor areas.
Solid underneath
Good gutters with some minor rust spots mainly from where we've moved the roof rack
I also have a few litres of the original paint so you wont even need to buy any initially, and I will include this in the sale.
Additional info:
1971 model registered October 1970, tax free, UK registered from new. Early bay with low lights to front, small lights to rear. Disc brakes fitted as standard from new but now upgraded to late bay discs, calipers and pads.
Receipts for around 95% of all work / purchases and all MOT certificates since we have owned the bus.
A wiring diagram of the leisure circuits – very important when buying a previously owned van – this labels all items and location for the leisure circuits.
Ø If you’d like to reduce the price then the fridge and roof rack are negotiable in the final selling price.
On request, if you purchase this van I can supply you with any of the photos of it from when we first owned it. The side view photo here is with the 3 bow rack and steel wheels we had on it originally.
NO CANVASSERS - ANY CANVASSERS WILL BE REPORTED
➢ £15250- Asking price is based on similar vehicles I have seen for sale but prices can vary greatly so I am being open minded with offers or swap for T5 (can be of less value with cash our way) as we don't want to give up the VW scene.
