Baywindow lock set on one key [SOLD]
Yo man have you got an ignition barrel for This set too an is it original or have you built it?
Cheers rob
Rob, no ignition barrel or I would have added this. Set is original and I have simply taken it apart to check all tumblers, greased and reassembled and given them a quick clean. Would also add the barrels in very good condition, all with matching correct tumblers and springs -checked as I had previously bought another set from a trader who will remain namless but only had a couple of tumbler in!
If you have and ignition you want added to this set or engine lid lock I can get this sorted for you but you need to supply the core
That was the reason I asked as I've heard people take tumblers out or file them down
An I didn't know if you had forgotten the ignition barrel that was all
Cheers rob
Cheers rob
Agreed, which is why I took them apart to check having been caught out before -and it was trade too :roll:
If you want to pop over to see the locks, quite happy to pull all the barrels for you to check -they are exactly as described, all matching tumblers. Can't say fairer than that
crazykid said:
Hi I have a 69 bay, will this lock set fit my bus ?
Kurt
Yes it would if the tailgate housings were swapped over -C&C sell these re-chromed or if you have a good second hand one I can arrange to get this done
Ok guys, keep getting asked if the lock set comes with a locking engine lid lock, please read the description and look at the pic (engine lid is non locking)
If you supply me with a locking engine lid lock I can arrange to get this on the same key for about £15 (pretty sure this is the cost from C&C). Same goes for the ignition barrel although the early ignitions were always seperate
