Mark6455 said:Sorry to jump on the thread but can someone tell me can I take out my single fosky adjuster and put machine 7 ones in without any probs.
My steering is damm heavy at the mo could this be down to the single adjuster?
Mark
Mark
Mark6455 said:Ok Karl thanks I'll get it checked out
Just out of interest exactly how low can you get on the fosky and how do you adjust it
Mark
Hi Karl that's exactly what I have in mind I'll have a play over the weekendWesty Richardson said:Mark6455 said:Ok Karl thanks I'll get it checked out
Mark
I had the adjuster welded in further round the top tube than normal which mines it will go lower. Mine is about 5 1/2 inches lower at the front.
To adjust it: Jack bus up, Undo the horizontal pinch bolt and slowly lower or raise (which ever you prefer) until you get a ride height your happy with and tighten the pinch bolt up, fooking tight at that! My Fosky adjuster is only a stand in until I can save up enough for a Slamwerkes king 'n' link pin narrowed beam, although they are considered a crude method these days a Fosky adjuster still gives good results imo.
Karl
