- Joined
- May 27, 2019
- Messages
- 489
- Reaction score
- 423
- Year of Your Van(s)
- 1969
- Van Type
- 1969 Bay Window
New thread - Whilst bleeding brakes I can’t get much fluid through driver side front brake and no pressure on pedal. Using the easibleed kit and there are no leaks and fluid passing through all other brakes … so thinking it may some kind of valve return /open situation at the master cylinder. I rebuilt it all a while back with new seals etc.
Have taken it off and have brake fluid squirting through all 3 outlets. Have checked the spring valves on outlet and they seem fine.
Any one have any thoughts on bench testing the pressure outlet on master cylinder or any other tests on the slave cylinders ??
Just trying process of elimination…. any thoughts or suggestions.. would be greatly appreciated.
