Brake pedal issue
66nige
Aug 12, 2014
261
3
staffs
Hi peeps, just a quick enquiry........ jumped in the bus this morning and realised that after braking the brake pedal wasnt returning to base position. I've had a quick look underneath and there doesn't seem to be any leaks on the master cylinder and the return spring seems intact...... Any ideas? :eek:
Possibly a collapsed flexi hose internally ? Had similar issues to what your describing a while back .
Have a look at the condition of them . You carnt really tell if it's collapsed inside but may be letting fluid through one way and not the other ? I normally end up with a collapsed flexi if i do some brake work and end up releasing the pressure eg bleeding bakes . New flexi and all was good again
Sent from my SM-J500FN using Tapatalk
Second one for a brake pipe flexi
