billybradshaw
Evening folks,
I've just assembled a new master cylinder and servo to my '71 bay and I'm left wondering now how I adjust the linkage to obtain the 1mm clearance between the pushrod and the master cylinder. Is this something I can actually achieve on a servo equipped bus? I only ask cos there is a large coil sprin inside the servo which I assume puts the push rod inside the servo in positive contact with the receptacle on the master cylinder pushrod.......
There isn't much in the Haynes regarding this, at least nowt specific for servo equipped models.
Also, it feels as if the brake pedal return spring is tired as it er......doesn't return the pedal, does anybody know where I can get a new one, can't find one listed anywhere............
Any advice would be welcome
Ian
Ian
