Supertramp
First 'breakdown' accelerator pedal went to the floor and didn't come back up. Had to be on the motorway didn't it.
Lee C said:Could you not wedge the carb open ??
Just to get you home like?
If it's not too far!!
creationblue said:A piece of string from the carb, around the bus thru the cab windowjob done.
Worth remembering if you got twin cabs the standard cable is to short, I ended using a connector block and some PVC tape as a bodge to get me home 8)
r73 said:creationblue said:A piece of string from the carb, around the bus thru the cab windowjob done.
I shouldn't really tempt fate but that sounds quite a laugh using string through the window :lol: I didn't know the std cable was too short for twin carbs, which cable should it be???
