Bus lowering
Nathan
Sep 21, 2014
113
Kendal
Hi all, my bus is currently lowered on an adjustable beam and two splines down on the rear so in reality has no suspension and rides like crap! I'm thinking of going drop spindles and adjustable spring plates. Who's are you using I've looked at transporterhaus and t2d. Any advice is welcome
T2D and T'haus will both be able to sort you out with these.
Alternatively you could try Graham at Midland Earlybay. He will supply and fit if needed, French Slammer parts: dropped spindles and spring plates etc, great service too.
Dropped spindles are the way to go if you want a smoother ride. :D
T2d and Thaus will give a you a 3.5" drop, French slammer is less so work out what you need.
If you have T2d or Thaus you will need to up grade your shocks. The trend seems to be either Gaz Coilovers or air shocks.
