I currently have water leaking into the cab so that when I lift the rubber mats it is soaking.
My first thought was the normal windscreen leaks but for the life of me I can't trace it, tried the hose pipe, talc etc but no joy. Also I had the windscreen replaced not long after purchase and the windscreen guys also used a bond to help with this so whilst I appreciate that it could still leak I would have thought that this would make it less likely.
I then got to thinking about the front grill and where the water that enters here goes ? Sshould there be some sort of drain behind the kick panels ? I've had a look and can't see anything obvious or where anything should connect to.
The bus is a LHD '71, so if there is something could anyone tell me which side of the bus I should be looking and also wher it connects etc. If anyone has any pics that would be a massive help
