baycrazy
Active member
Hi There I'm new to this forum but was hoping someone might be able to help, I have a 71 Westy with a 1600 twin port, runs ok a little hesitent when back on throttle from off throttle/changing gear etc. But worse is every now and then when the engine is hot it will go from idling fine to spluttery and stall, the carb at this stage has fuel coming out, it hisses and spits and will only start after removing the air filter and allowing the fuel to evaporate. Its a new 34pct and fuel pump(dead embarrassing when it happens) any suggestions would be much appreciated. Really don't want my bus to catch fire!!
Great forum by the way been meaning to join for some time, will get some pics together and post at some point!
Cheers Paul
Cheers Paul
