philstar
- Joined
- Dec 27, 2011
- Messages
- 196
- Reaction score
- 20
- Location
- Redditch
- Year of Van
- 1971
- Van Type
- Panel van
Hi folks,
I'm trying to set my engine up to drive it for the first trial drive (page 171 in Tom Wilson's "How to rebuild your Volkswagen Air-Cooled Engine book) however I'm concerned by what sounds like a knock, and also it's developed a regular "miss" (?!) after my initial timing and carb setup. I adjusted the valves prior to this, and both on cylinder 4 were very loose. You can see that when I blip the accelerator it just stutters and eventually dies, I can hear a hissing but all connections feel tight. If I rev it slowly it seems to rev ok though.
I have a handy video recording you may be able to listen to / watch here:
Video of engine running rough
A few specs:
Can anyone give me any advice on what to try next, or what is going on in the video? I want to avoid doing any damage, but I have to admit I expect to rebuild the bottom end next winter once I've finished spending all my money on a wedding...
A few specs:
- Stock 1600 dual-port rebuild—internals assembled by a local company, but that was about 6 years ago. Crank was reground and polished, all new bearings etc. Case has seen much better days.
- Facet electronic fuel pump to replace standard mechanical pump
- SVDA distributor (Barely any miles, new replacement prior to rebuild)
- Blue coil (Barely any miles, new replacement prior to rebuild)
- New cylinder heads, barrels, pistons
- 34PICT3 carb (Barely any miles, new EMPI replacement prior to engine rebuild)
- Static timing set—but the indicator light was always on, I turned the dizzy until it went off, which seems to be the opposite of what I expected (connect to coil negative and grounded on the alternator)
- Automatic choke was checked and refitted, and doesn't seem to be coming all the way off, there are no visible marks to line up.
- Carburettor bypass and volume control screws reset to 2.5 turns (also tried 3 turns), fast idle screw set to touching cam and 1/4 turn in.
