Check out Ben's new look Bay narrowed beam conversion - it's the Daddy!
AirKraft have been up to tricks recently converting CB Peformance 4 inch narrowed Split Bus beams to fit Bays of all years. Using Split Bus dropped spindles and Split trailing arms, you can go super-low without the hassle of snapping ball joints etc. The ride is super smooth, also.
Using a laser-cut adaptor bracket designed in-house, it is possible to adapt a Split Bus CB beam to fit a Bay window in approximately one hour!
Hope you like the before and after pix folks! 8) Cheers, matt k
Before... lowered about as much as you can go on ball joints
Not great tyre clearance...
The beam modded to fit
Bolted up...
Post op...
Mother Tucker...
Bolted up...
Post op...
Mother Tucker...
