Bigbear
Does anyone still use there's or are they usually thrown away? Are they available to buy still?
EgoTrippin said:Mine was disconnected when I got my bus. Only recently removed it so its available if you need one.
Araon said:The only way it will have caused a fuel smell is if the pipes have been left to vent to atmosphere and not into the air filter.
Ditch it and chase up all your pipes, engine out and replace old for new and use correct clamps
They were used to meet US clean air regs
hart5lizard said:Dont wait to check your fuel lines if you are smelling petrol,
I discovered the pipe connected to the petrol tank had split right at the end & was only just hanging on by the skin of its teeth, I just touched it ever so slightly & it came away allowing a torrent of fuel to pour straight
from the tank!
I was very lucky to have discovered this while i was under my bus & not driving along
scary
