Mikesmithmedia
Instagram :- @bimmergirl_cheryl
- Joined
- Nov 10, 2022
- Messages
- 38
- Reaction score
- 33
- Location
- Midlands, Uk
- Year of Your Van(s)
- 1972
- Van Type
- Kombi
Put an electric fuel pump in which gives instant fuel when ignition is on. (not dependent on engine turning over to give fuel to carb) Eliminates possible fuel leaks into sump too. Have you changed the flexible fuel breather connections behind the firewall? Engine needs to be out for this so the tank breather connections are accessible. This is an important thing to do as this is an extreme fire risk especially when the tank is full which expands in hot weather. The pipes and connections are hidden away and probably have not been replaced ever. These will be brittle with the E fuel. Look in the side air inlets and you will see the expansion vessels which look like little bottles. The pump is Facet made in US. Use ethanol fuel inhibitor to protect tank etc. Drawings show where flexible connections are. Also consider a fire suppressant system. What's your van worth to you? £200 might seem a lot but it is protecting thousands of pounds worth of your hard earned money ??
Thanks for the info
£200 for fire safety isn’t a lot of money at all
