Coil mounting?
lower down on the fan housing?
find a garage that has a rivet nut gun and get them to put two rivnuts or nutserts into the fan housing lower down so you can mount the bracket holding the coil lower
you can get a bracket to mount it behind fuel pump and if you run elctric pump a blanking plate with ciol mount.
Mine wouldnt fit with a CB linkage, so I used the CB coil mount kit ... there about £15.
Write your reply...
