After dropping the engine out to replace the flywheel oil seal and put it all back together i then found my dynamo bushes were buggered.
We had a external regulated alternator in the box of spares so did this swap 2 weeks ago.
The magazine article is a good reference but doesn't cover everything you need to know like new wiring.
Try this for ext. regulator
Or if you look in the green hyanes manual you will spot that the American wiring includes an alternator instead of dynamo.
I found that my upright fuel pump fitted even with the larger alt. stand but only just! If you do change to the angled fuel pump remember it needs a shorter pushrod (GSF sell them for about £4)
In my 72 there was enough room to lift up the fanshroud to remove the dynamo with fan attached although i do have twin carbs which meant i didn't have a manifold in the way.
Don't forget if you need to swap your fan over you need a breaker bar and big socket.
I also have a leisure battery and split charge relay, as already mentioned they are really a trickle charge to keep them topped up. After running my leisure battery down to 9.5 volts it only went back up to about 10.5 after 1.5 hours of driving home.
While running i have noticed that the main battery is showing a higher reading compared to when i had a dynamo.
