cross over horn
bug power
Oct 20, 2006
13
nottinghamshire
the horn don't work :shock: tested the horn straight on the battery and it works :D had voltmeter on the wiring and that works as well :D then put the two together and :cry: the dam thing forgets what to do
You can get a reading on a voltmeter which will tell you what potential you have,but won't tell you how much current can pass.Probably you have a bad connection somewhere.Fistly try running an alternative earth to where it should go see if the horn works,if so you need to check the earth from the button through steering column to the horn and the earth to the column itself.If you need a live to get it going check the feed from the fuse ,to the fuse and to the horn itself.Best guess is it is a dodgy fuse /fusebox connection or the horn button itself.
