Cv joint bolt torque settings.
thejinx
Mar 30, 2011
1,559
73
swansea
Just changed my cv boots. However when I took the damaged ones off (been on less than 2 years). The bolts were loose. I’ve nipped up the new ones but I’m scared to put to much pressure on as they seem very prone to round off.
Firstly what are the correct torque settings I’ve read somewhere 44nm
Second I am using a mixture of 6mm Allan key and torque bits but nothing really feels like I can put some pressure on without rounding them off.
Cheers all
Cheers all
It’s 25 footpounds in Bentley, which is 33.9Nm. This is for the socket head bolts. Don’t forget the schnorr lock washers.
If the bolts heads, that is the socket inside, is damaged at all it’s best to replace them.
Sent from my iPad using Tapatalk Pro
The original bolts were neither hex head or torx, but tri-square. Replace them all with new ones from Butty's Bits.
https://www.buttysbits.com/?product=bb-047-baywindow-t2at2b-cv-joint-mounting-kit
some were allen key, some spline
