Quick question with regards to CV joint reassembly after cleaning.
On the outer hub, this has a groove running around one of the outside edges, should this be fitted facing the rubber boot or away from the axle ?
The one I've removed has it facing the rubber boot but when googling I've found different opinions on different web sites, just wondering which the right way is ?
With regards to the other bits I' think I'm good in that :-
Inner hub - the side with the ridge faces the rubber boot
Cage - the side with the thinner edge faces the boot
Also, finally, do you also fit the washer that is supplied with the kit as, again, there are some websites that state that this should be discarded
Many Thanks
Many Thanks
