gman4175
experienced a fire in the dash on the way into work this morning, caused by a live wire coming loose & shorting against metal work under the dash. managed to stop the engine, pull over & give it a blast from a dry powder extinguisher i keep at arms length in the cab. luckily, the only damage done was one of the ignition wires was completely burnt out. burnt out wire replaced with some i keep in the glove box & i was back on my way within 15 minutes.
big thanks to the old boy who stopped to see if i needed any help? and helped me push my bus off the side of the road.
and if you don't carry any sort of extinguisher, i'd recommend getting one.
