Distributor choice and why?
dubdubz
Jul 10, 2007
2,549
5
Peterborough mainly never Cornwall
So if you had to replace your dizzy with something new cos it was not giving you very crisp timing, what would you replace it with and why??
I want electronic ignition of some sort, too lazy for points! and not adverse into looking at wasted spark sysems too
so what's the bestest and why?? had better throw a budget into the mix - lets say upto £200
thanks
D
engine is in a bus, twin dells with vac take off, and is 1745cc in size.........
I'm gonna step out of line here and say if you have a nice usable cam like a 110, there's nothing wrong with a Bosch 009 and Pertronix 2 ignition. No vacuum leaks to worry about either.
You don't need to spend loads on a dissy for that size motor.
What crank you running by the way, I've never heard of 1745cc before. :?:
Loxy said:
I would guess a 76mm with stock b&ps, as my 74mm crank with stock b&ps makes 1699cc.
correct :D 76mm cb crank, Mahle forged 85.5 B+P's and DRD G03 heads with 3 angle valve job.......
I have a vac dizzy but I think the shaft or somethings worn as the timing isn't tight, I was thinking of crank timing and ford edis but not sure - I haven't yet found a decent source for decent 009's - most are junk with advance curves that are inconsistent
the repro vac ones are they any good or should I plump for a 123dizzy? and if so with or without vac?
the 1745 was an experiment - it was tricky to do in terms of deck height and shims, it does mean that when I decide to go 90.5 I'm there in terms of carbs/heads - I wasn't ready at the time to do it all!
anyway back to Dizzy's -anymore suggestions??
D
I can't say from experience but if I had the money I think I'd go with the 123 dizzy - a complete unit from one trusted/quality supplier with a good reputation (from what i have read)
it's in my choices but at the upper end of my budget - who's had good experiences of repro vac dizzy's?
I am currently running a genuine new Bosch SVDA with normal points that runs very well - no noticable flat spots and pulls well. Just like the idea of lower maintenance modern electronic ignition.
where did you get the bosch from if u don't mind me asking?
i have a 1600 tp with ict's and a 123 with vacuum. never misses a beat. got mine from sc acr parts
Heritage - they're about £100 - or at least that's what I paid about 18 months ago.
I assume it's got a fair bit of torque?
