Zcat7
- Joined
- Apr 12, 2010
- Messages
- 670
- Reaction score
- 11
- Location
- Oxfordshire
- Year of Your Van(s)
- 1972
- Van Type
- Crossover
I still haven't fully run my 1776 engine in since building it some months back. It does pull well when up and going but to be honest it hasn't been running as smooth as I'd hoped at lower revs and I'm getting a bit cheesed off trying to set it up. The crap weather has played its part in that but the latest problem has occurred twice now, the second time after about a 30 mile run. No1 plug carbon fouls to the point that the spark fails and it runs on 3 cylinders. No2 plug works fine and if I'm reading it correct, has a good colour indicating indicating that it is firing fine and the mixture is good.
I'm running twin solex 40s rejetted/venturi'd for 1776 by KaddieShack, have replaced all plugs, leads and the dizzy cap. The dizzy was changed from a 009 to an 034 SVDA with Autospark points to try to cure a mild vibration at around 1600rpm (and it got better) but I'm still a bit confused about what timing I should set. Currently it is set to 7.5 BTDC (vac off) but that gives me about 32 degrees max advance (vac connected). It doesn't rev up smoothly to accelerate from standing, if you blip the throttle it hesitates before spinning up so I'm thinking I might need a touch more advance. But that would make my max advance about 34 degrees, which I'm guessing is too much?
Compression check shows all is good and within a couple of PSI around 122, which I think is good for a sub 200 mile engine. I have also reset the tappets twice, although all was OK anyway.
Anyone got any suggestions what could cause a poor burn in 1 piston only and what I should do about the timing?
