Doors dropping
thejinx
Mar 30, 2011
1,568
79
swansea
Ok. Doors fitted back on van after spraying and closed fine. Bought new rubbers and removed pins from door straps to fit rubber. Once pins are back and rubbers are fitted the door seems to have dropped.
Can't be the removal of the pins so I think it is the rubbers pushing on the door when closing making them mis Align. Your thoughts please as I am loosing the will to live
Cheers in advance
Your right, new rubbers will not cause a door to drop.
Try lifting the door. If its dropped due to wear then you will be able to move it up and down.
If it moves then look to see where the movement happens.
