Seamus1982
- Joined
- Apr 29, 2010
- Messages
- 130
- Reaction score
- 0
The sliding door mechanism on my 69 LHD Westy works fine, with the exception of the lock 'switch' internally (above the handle, teardrop shaped white plastic). In the 'up' position, the door is unlocked internally, but in the 'down' is locked and won't allow the external handle to be lifted to complete the closing stage for the door. The switch is completely loose and won't stay in the 'up' unlocked position.
I assume there should be some type of spring mechanism that holds this small switch in place, does anybody know if this is mounted externally, or is it within the door mechanism itself? The switch appears to have a small hole in the end of it that could take a spring. I can't find any detailed diagrams which show this element.
Any help would be appreciated. I don't want to replace the whole mechanism as it is original and works fine otherwise, but I would like it to perform as intended.
Thanks in advance.
Thanks in advance.
