dormobile roof bellows
williamharris
Jun 24, 2014
8
hi all i am just about to start to fit a new roof bellows to my early bay dormobile just wondering if any body has any info or photos they could share with me
thanks in advance
Did my bellows last year. Not a hard job, laid my roof on a table covered with a quilt to protect it. I found the best way to do it (for me). Firstly make sure you have the aluminium strips in the right place. They are bespoke so my'n only matched in the correct places. I swapped out my brass nuts and bolts for stainless.
I found it best to use a small piece of welding rod sharpened to make a small hole before pushing the bolt through and putting the nut on. You could use anything as long as it's not to thick. I did the ends of the strip first and then worked in. Getting the corners right is essential.
I had been advised to double up the material but didn't as i felt it would have been tight once attached to the van.
The strips go on the outside by the way.
It took me a day to put the 4 strips on, wasn't to hard once you get into the flow. Scary at first as you don't want to rip anything. I didn't tighten up all nuts until the end. Hope that helped.
Is your roof still on your van? I don't know if would be possible to do it in situ. The strips tha attach to the van go in the outside apart from the one next to the hinge which is inside
Thanks for the last reply
roof is off the vehicle
the last coment about final strip next to hinge going on the inside
Was a great help I couldn't get my head around it :D
