68only
Basically drop your van off to me and I will lower it fixed height front and rear normally in a day for £325. If you want more than 1 spline on the rear you will need to add £60, as I will have to notch/clearance the springplates a little. This is not a cut and turn, but uses the same method as fitting adjusters, but without the cost. It will be adjustable by someone with some skill. If you want DIY adjusters add £100.
I find most people want it a certain height and then never mess with it again. With this method both tubes are adjusted, so the ride stays good. This is fine for upto around 4.5" lower. Any more than this you will start to compromise the ball joints.
Now taking bookings for 1-2 weeks time.
