noddy
Hi
I need some help.
Have been fitting new drive shaft boots today after van failed mot on split boot.
The problem Im having is finding the right tool to spread the new circlip to hold the cv joint back on the drive shaft.
The only sort of circlip pliers I can find are the ones with the round end, the circlip I need to spread is more like a piston ring so need circlip pliers with flat ends.
Does anyone know where I can get this type of pliers from? or should I be looking for a tool with another name, and if so what are they called?
Thanks all
Ian
I need some help.
Thanks all
Ian
