68only
Going to DF in the AM. Here's a few bits lying around I can chuck in the wagon..
Early bay small world brochure £20
AS41 Engine case, looks OK inside £45
Oval beetle or split bus accessory dip switch £50
Straight axle handbrake cable adapters fro T2d £15
Bay dash/bulkhead bubble vents £15 pair
Bay cab door handles - german ones in OK shape £20 pair
6 volt 200mm flywheel £25
Brake fluid reservoir, 61 only £15, has lid.
Early bay engine lid latch in good condition £20
NOS H1 french yellow headlamp bulbs £10 pair (2 pairs available)
Late bay genuine fuel cap, stainless, will polish up nice £15
Swedish first aid kit, well stocked! £15
Alloy clip on rocker covers £10 pair, need a clean up!
Early bay Devon table bracket and re-inforcer £20
Loads of stock or aftermarket wheel nuts, bolts, etc. Aftermarket £1 per nut/bolt. Tell me what you need. Some new, some used.
Bay rear load grille £15 from swedish army bus
2x non doghouse fan shrouds £10 each
Late bay shift rod x 2 £20 each
Late split rear drums £15 each. Late split and early bay front drums £15 each. Have a few of each
Type 3 oil coolers with pressure switch take off - can be used on damaged T1 cases £20 each
Single port head shrouds £10 pair
Early bay deluxe door cards set except slider for LHD bus £60
Bay front disc backing plates £30 pair
Heading off early am or will courier anything you require usually £7.50-£10 for most things.
