This is what the Old Volks Home says
Bus & Pickup 1969-1970 * 1600
Distributor: VW 113-905-205T, Bosch 0231 137 035 or 036
Can Use: VW 113-905-205M, Bosch 0231 137 021
Replacement: VW 111-905-205AA, Bosch 0231 137 039
Points Replacement Plate Assy: VW 111-905-227B, Bosch 1237 110 139
Condensor: 02 007 - Note: If equipped w/AC use 02 069
Rotor: 04 033
Cap: 03 010
Parts Kit (Washers, Shims & Hardware): 059-998-211, Bosch 1237 070 007
Coil: 00 015 (Blue Coil: 00 012)
Vacuum Can: 07 024 (Replacement uses 1237 121 400)
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 0deg TDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum (Advance Only): 17-19deg @ 1.3 In. Hg, 32-35deg @ 3.2 In. Hg
Ideally you want an SVDA dissy which has mechanical advance as well, give much better performance.
We have this dissy fitted to a 1641 in a '68 Bay which is what it arrived from the states with (the dissy not the 1641)
Bus & Pickup Late 1976-1978 All States, 1979 Federal * 2000
Note: This Distributor also fits Type 4 (412) 1974
Distributor: VW 021-905-205P, Bosch 0231 168 005 > 022-905-205S, 0231 170 093
Note: 0231 170 093 dist primarily used on California Late 1976-1978 and all Federal 1979 Models
Can Use:
Condensor: 02 074
Rotor: 04 033
Note: 0231 168 005 dist originally equipped with Speed Limiting Rotor 04 016 (5400rpm)
Dust Cover: 039-905-241, Bosch 1230 500 139 > 1230 500 147
Cap: 03 010
Distributor Cap Clip: 034-905-265, Bosch 1231 251 033
Parts Kit (Shims, Washers & Hardware): 059-998-211, Bosch 1237 010 007
Coil: 00 012
Vacuum Can: 07 060
Ignition Wires: 09 171
Spark Plug: W8CC
Timing Set At:: 7.5deg BTDC @ 850-950 rpm (Man Trans), 900-1000 rpm (Auto Trans) w/strobe, vacuum hose connected
Advance/Retard Range: Vacuum: 8.5-11deg Adv @ 7.9 In. Hg; Centrifugal: 8-13deg @ 1600 rpm, 20.5-24.5 @ 3400 rpm
