Dynamo/Alternator Help required!
rubberdubber
Jan 8, 2009
86
Aldershot
Hi all
Finally got myself another engine for my bay yesterday, this one has come with an alternator :D My old engine had a dynamo, now im not sure if i need a regulator for this alternator or if theres one built in? Also any help or tips on wiring the damn thing in, much appreciated!
thanks in advance :)
*external regulator*
B+ is the fat red wire from your starter, the others (D+, DF & D-) are connected via a funny little socket to the regulator you haven't got :wink:
*good luck*
8)
how dissapointing! Any ideas where i can get one from? Is the 3 pin plug part of the regulator or is the wiring seperate? I found this on JK but it only has 2 wires :?
http://www.justkampers.com/shop/type_2_bay/type-2-bay-original-vehicle-parts/engine-electrics/dynamos-alternators/voltage-regulator-external-50amp-for-alternator.html" onclick="window.open(this.href);return false;
Ok i have done some research, struggling to get my head round it though, from typing the part number into google, i have come up with this regulator:
http://www.woodauto.com/component.aspx?Ref=VRG3639" onclick="window.open(this.href);return false;
with the old engine the wires came out the dynamo into the regulator then on to the battery, with this alternator do the wires just go straight from the alternator into the regulator and stop there? then just connect B onto your battery +? and thats it, no earths?
cheers
The alternator probably earths via the case if i remember correctly. One of the terminals of the voltage regulator needs to be connected to the cable which feeds the gen light on the speedo to provide a voltage sensing circuit too.
Cheers, have been studying the wiring diagrams and all making abit more sense now, got a new regulator off ebay for £11, better than £30 from JK!
