OK. Most people will tell you that it's a faff, and normally it is. Normally the route is similar to:
Remove air cleaner
remove carb
loosen and remove manifold ends, this will include removing the rear tinware to get access to the inlet manifold (centre section) pre-heat screws.
remove 4 x screws holding the dynamo backplate onto the fan shroud (fiddly! Inlet manifold is in the way)
remove dynamo strap
remove dynamo stand, undo 4 x nuts holding in plate (fiddly! inlet manifold is in the way)
remove dynamo
celebrate, nurse broken fingers
However, there is a second way. It's not always possible, but if it is it'll save you a bumload of time. The main problem with route 1 is that the fan is too deep to get the dynamo out at any cheeky angles, so we remove the fan.
remove air cleaner
remove dynamo strap (fiddly! carb in way, can remove it if ya fancy)
with a 36mm socket, 4" extension and ratchet, and with a screwdriver in the slot to hold the upper pulley still, undo the centre 36mm nut on the back- so reach around, and undo it blind. There are two big washers between the fan and the housing.
remove 4 x screws holding the dynamo backing plate onto the fan shroud
remove fan assembly
Celebrate.
Hope this helps
